Engine spray paint
groundhog
Engine spray paint
Post by groundhog » Sat Jul 27, 2013 7:36 pm
For silver engined owners If you are looking for a good spray paint to refresh and smarten up engine fins, crankcases etc I would recommend Halfords 'Very High Temperature Aluminium' spray. It matches the colour of the engine perfectly and as you can guess from the name it can stand the heat ! Can't remember the price as I bought it ages ago but I think its seven or eight quid. Just done what I could get to without taking of the headers and it looks like new ! I'm generally rubbish at spraying but found it really nice to use. Just remember to use plenty of masking tape !! Will do the rest as a winter job.
Trev
yamy66
Re: Engine spray paint
Post by yamy66 » Sat Jul 27, 2013 8:26 pm
I have used this before and it does look good - the only drawback was the corrosion under the paint came back through after a couple of months - you need to paint some gel-type oxidiser on to kill off the corrosion -then wash off and the spray coat should last longer
Facebook : Keith Hamilton Artworks
groundhog
Post by groundhog » Sat Jul 27, 2013 9:59 pm
Thanks for the tip :thumbs: In the winter I am going to take the pipes off and do a proper job so will do as you suggest
Trev
Irish 1200
Post by Irish 1200 » Fri Dec 20, 2019 12:33 am
I know this is an old post but it's worth a try, did this paint work?
Lampy
Post by Lampy » Fri Dec 20, 2019 11:40 am
I and a lot of others have used this stuff .https://www.ebay.co.uk/i/113701184529
Best applied using a quality (artists) brush and stipple it on. 250ml
250 ml tin will do many engines :thumbs:
Good match just needs to be heat cycled a few times to harden it off fully.
SO MANY LAMPOSTS...........so little time . . . . STUPID PLACE TO PUT A WALL WASNT IT !!!!!
OH DEER !!!!
Irish 1200
Post by Irish 1200 » Fri Dec 20, 2019 5:52 pm
Thanks Lampy, much appreciated.
