LED rear light
Moderators: RFdemon, Site Team
Akirasan
Contact:
LED rear light
Post by Akirasan » Thu Jul 18, 2019 10:38 am
I have fitted a 2007 twin round rear LED light to my 2000sp 1300.
everything works but when full lights are on the rear light dims.
When the engine is running the lights brighten but flicker with the revs.
If i put an extra live feed to it they are better but not perfect.
Any ideas??
If in doubt accelerate
hairy
Contact:
Re: LED rear light
Post by hairy » Tue Jul 23, 2019 1:10 pm
sounds like someone may need a new battery...or could be a bad earth somewhere...had mine on for quite some time with no problems mate
New and used XJR parts :arrow: http://xjrparts.co.uk
INDEPENDENCE DAY...31 January 2020 :D
Akirasan
Contact:
Re: LED rear light
Post by Akirasan » Tue Jul 23, 2019 1:29 pm
Battery ok did not do it with old led rear light
front h4 does not flicker like the back new led.
will see what the led headlight bulb does
harris
Membership Sec
Membership Sec
Re: LED rear light
Post by harris » Tue Jul 23, 2019 3:43 pm
Led might need a different relay, I know my indicators did. Is your reg/rectifier ok.
Akirasan
Contact:
Re: LED rear light
Post by Akirasan » Tue Jul 23, 2019 4:37 pm
Already has led relay for indicators they are not the problem its the rear light.
hairy
Contact:
Re: LED rear light
Post by hairy » Wed Jul 24, 2019 12:44 pm
Maybe a fault in the light itself...is it a chinky chonky or OEM?...no relays needed for the OEM one
