Single Speedo.
Paul H
Single Speedo.
Post by Paul H » Thu Nov 24, 2016 11:00 pm
Looking for a single cable drive speedo for RP06. Not that worried about idiot lights or tacho. I can also make a mounting bracket to suit. Any suggestions on brand or model. Theres a million out there but not sure whats compatible with the cable fitting. Thanks.
Stokoe0990
Re: Single Speedo.
Post by Stokoe0990 » Fri Nov 25, 2016 1:20 am
What sort of aesthetic are you looking for?
I've got a singular one on mine which is all LEDs and stuff, with rev counter, fuel gauge, digital speedo. etc.
But if you want something a bit more basic then a little thing like this might be better...
http://www.ebay.co.uk/itm/UNIVERSAL-MOT ... Sw-zxWpgjz
Jap Import 1997 XJR 1200 | 45k Miles and counting
The bike in the picture above is being broken for sale, check out my post here to see what's still available.
Paul H
Re: Single Speedo.
Post by Paul H » Tue Nov 29, 2016 10:52 am
Stokoe0990 wrote:What sort of aesthetic are you looking for?
Something like that one but normal size.
pognasty
Re: Single Speedo.
Post by pognasty » Tue Nov 29, 2016 12:43 pm
Have a word with digital speedos. They're very helpful and as a club member you'll get discount.
There is no warm up or cool down. Life is only one lap - make it a good one, make it count
Paul H
Re: Single Speedo.
Post by Paul H » Sat Dec 03, 2016 9:38 pm
What model did you go for & was it a dificult to convert. I need kph which I would imagine would be a option on most digital speedos but never thought this conversion was possible from cable drive. I flopped the headlamp brackets to raise the bucket. But now the stock guages look more bulky and hinder the ignition access so a low profile digital may be the way to go. I would not mind relocating the ignition if possible or doing away with the steering lock if need be though. Cheers.
Stokoe0990
Re: Single Speedo.
Post by Stokoe0990 » Sun Dec 04, 2016 1:27 pm
If you look through my post history you'll find a thread about it.
It's mounted rudimentary-y at the moment but works.
Paul H
Re: Single Speedo.
Post by Paul H » Mon Jan 09, 2017 10:33 pm
Thanks for the replies. After a lot of head scratching & beers I ordered a Koso DB-01R digital unit with LSL 6.5 round Headlamp & Brackets to trim the front. Plan is to place all the instrument plugs under the tank & run 1 small loom to the Koso. Cheers.
