New oil cooler fitted
psycho46
Re: New oil cooler fitted
Post by psycho46 » Wed Jan 06, 2016 9:23 pm
try this fleebay item number 171969646594 for the oil cooler, its not quite the same as in this thread but its the one im using. mainly 'cos its black and i prefer the look. This is the bracket fleebay number 400980821482 just needes new holes drilling.
People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs.
hairy
Contact:
Post by hairy » Sat Jan 23, 2016 1:04 pm
Got some T&M racing oil cooler kits for the XJR1300 and 1200....advertised on fleabay item number 381528025545
just got a few in stock but planning to get some more if enough interest
£210 including postage to full members pm me if interested.
New and used XJR parts :arrow: http://xjrparts.co.uk
INDEPENDENCE DAY...31 January 2020 :D
Stokoe0990
Post by Stokoe0990 » Tue Sep 06, 2016 12:03 am
Skyrider - you find this out yet? :D
Jap Import 1997 XJR 1200 | 45k Miles and counting
The bike in the picture above is being broken for sale, check out my post here to see what's still available.
Stokoe0990
Post by Stokoe0990 » Tue Sep 06, 2016 12:47 am
Ok so I've done all the figuring out of how to build a kit "LIKE" this one on the cheap. (£140 to be exact).
All that's missing is the resevoir bottle and connection to oil filler cap. Which may not even be necessary? (I don't see it on some people's bikes, only on a few).
Anyways, without further ado:
Hose
Hose is 1m long "AN10" (14mm outer diameter)
Radiator/Cooler
13 Row, AN10 connections, Aluminium
Fittings
2x Straight AN10 connections - for sump
2x 90 degree AN10 connections - for cooler
Converters/Connectors
This is an unfortunate necessity - the standard XJR oil hoses don't have a regular connection, so we need to buy these, they bolt up the same way the OEM cooler does, but have an AN8 threading on the outside, instead of just being direct hoses to the cooler.
1x Pair of XJR Sump to AN8 connectors
This will take that AN8 threading to AN10, to be compatible with all the parts, connect directly to sump
AN8>AN10 converter
This SHOULD be all you need to switch to an aftermarket oil cooler. You'll have to make your own mid up on what to do with bracing the hoses, but I'd personally just use cable ties if you cut the hoses too long or something.
So the idea of flow is: Sump > AN8 connector > AN10 adapter > Straight AN10 fitting > Hose up to cooler > 90 degree AN10 connector > Cooler > <<Reverse (Connected to the other side of the cooler, obviously!).
I'll let you know once I've got £140 spare to try this out for myself!
jooles
Events Coordinator
Events Coordinator
Post by jooles » Wed Sep 07, 2016 5:32 pm
the bottle on the side has nothing to do with the oil cooler ,its a catchment tank, when you fit a window clutch cover as they have no baffles inside to stop the oil being thrown out the breather pipe ,,,
jooles
Events Coordinator
Events Coordinator
Post by jooles » Wed Sep 07, 2016 5:37 pm
you might want to rethink on the braided as it runs close to the exhaust ,they do a better grade on there site that will take the heat ,,,,,
